Fusion Support
Bottom Tool Bar has move left
1 REPLY 1
harpo3196
113 Views, 1 Reply
Hi All
In a couple of my assembly drawings the bottom tool bar as moved to the left and is partly covered by the comments panel. I can't work out how to it back to the center. Any ideas
1 REPLY 1
jhackney1972
in reply to: harpo3196
You may have already tried this but under the File menu, select View and then select Reset to Default Layout.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
