I have a body that acts as if were there but I you cannot see it. I can see the ghost shadow though. I can export it as a mesh. It started out of thin air. Thanks -scott
Solved by jhackney1972. Go to Solution.
Please attach the model. If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Could your Opacity be turned down real low?
John Hackney
Retired
Have you saved, and closed Fusion then reopened it up? Sometimes this will reset the graphics.
John Hackney
Retired
Looks fine on my end.
Edit: Have you looked at your Visual Styles?
John Hackney
Retired
