Fusion Support
Body appears as disjointed surfaces
3 REPLIES 3
rjeAT6XG
135 Views, 3 Replies
1.  I'd like a private way to report bugs as I'm an employee and I can't publicly disclose my models.
2.  I took a screenshot of a corner of my model that hopefully shows the problem.  I've pulled my design history back.  The white surfaces should continue on the top as it is all one solid body, but it's as though the top surface isn't there.  Moreover, some entire features are invisible.  Sometimes when I switch display modes, it shows up correctly, but then disappears again.  When I pull my history forward, the model appears correctly.
3 REPLIES 3
jeff_strater
in reply to: rjeAT6XG
it could be a graphics problem, a problem with the model, or just some misunderstanding.  But, we'll need the model to tell for sure, can you attach it to a reply here?  Thanks
Jeff Strater
Engineering Director
rjeAT6XG
Next time it happens, I'll contact support.  Thanks!
rjeAT6XG
I contacted support when this occurred again.  When it occurs, click modify-compute all or command-B and it seems to correct it.
