Hi, sorry if this isn't the correct board. I didn't know which one it would go under. I am working on designing a sign off of an SVG. Extruded the base of the sign to create a body. But when I do a second extrusion to raise the walls/edges of this sign and try to join the two I get errors. Something about a coincidence previously not being a coincidence. And when I extrude that second extrusion by itself it work. But when I try to combine them it says general modeling error. Confused as to why it is doing this when a sign I previously made for my nephews worked just fine using the same process.
