Fusion Support
Bodies lose faces after latest update.
1 REPLY 1
wacarr6GHYL
81 Views, 1 Reply
If I try to move through the timeline before turning this body into a component it loses faces, I deleted the 'turn body into component' item in the timeline and lost all the faces.
It only started doing this after the latest update and appears to only be doing it with this file.
Is this file lost, or does anyone have a fix?
1 REPLY 1
jhackney1972
in reply to: wacarr6GHYL
Cannot tell without seeing the file, please attach it.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
