Announcements
Blend or smooth lines on body
Hi all,
Apologies if I use the wrong terminology - I'm very new to this.
I am wanting to print clay/fondant/cookie texture stamps. The stamp portion is extruded 6 mm and the base plate is extruded 4mm.
When it is printing, the bottom layers are printing the pattern instead of just a smooth solid base. I have attached so photos to try and explain what I mean.
The top is fine but I would like the bottom to be blended/smoothed etc so you can't see the patterned lines on the first layers when printing.
I hope I explained that ok.
Any help would be greatly appreciated.
Cheers,
JD
davebYYPCU
Not clear at all.
Are you saying the bottom 4mm of the print is not solid, and the top 2mm is all OK.
That will be a bottom layer setting, if the Fusion model is OK..
