@jan_ekholm wrote:
I don't really see what good a video would do here. I assume you're not working on the code itself? Do you use the Mac version? It seems Windows is the primary platform and it's probably really stable there.
I've used the Mac version since 2014 across 2 different Macs. I started on a mid 2010 iMac. Then I moved to a 2017 MacBook Pro. The iMac isn't used for CAD anymore. The Intel MacBook Pro works just fine for Fusion 360.
Nowadays I do most of my professional work on a Dell Precision notebook and peronal projects on a PC purpose built for rendering, designed around a AMD Ryzen 5950 with 64GB of memory and NVIDIA 3070ti graphics card.
From a Fusion 360 standpoint, performance wise the Dell and the the MacBook Pro are close with the Dell having a slight advantage. I've run extensive tests! I have not seen, or do I currently see a functional difference between the MacOS version and the Windows machines.
The macOS version is as good as the Windows version. I know a good number of the Fusion 360 team members personally and through online meetings and many of them use the macOS version of Fusion 360.
For the black screen issue a video won't do a thing.
For workflow related crashes, having a video and a a data set/design will definitely be helpful. I've not experienced a crash in Fusion 360's Sketch engine in ... heck, I don't even remember!
