Hi, Total Noob here. When taking my course in F360 it showed the "Isolate" feature. So I tried it out on the Bike Frame sample. When I isolate an assembly such as the shock as soon as I unisolate it the rear triangle goes to a flat set of planes instead of back to the original shapes. I am a professional dev so I tried it several times in different ways and its easily reproducible. If I do a save as it even saves the objects in that state and rehydrates them from a saved file that way. The second bug is that when I animate/move the triangle the shock over extends and pierces through the frame instead of stopping at a contact point. This may be expected behavior of a drawing without a properly set extent but its surely not as the sample was intended. I also randomly had the pin/bolt from the shock relocate in space but that one I can't easily reproduce. If this is just my noobness talking please excuse me, just thought I would bring it up.
2.0.10356
Active Plan: Fusion 360, Student
Windows 10 (19043)
