Announcements
Bevel Befuddled
bobus17821
Bevel Befuddled
bobus17821
In this model I am working on ...
I'd like to bevel the edge between the face of the part which projects into the box and the edge of the inside of the box.  But I created a problem when I extruded the part which projects into the box by joining it.  So now I don't have an edge where I need one.  That's what the construction line (pointed to by an arrow) is about.  I thought that would help but I have not found a way to make it help.  Of course I could start over or perhaps backup but that would be admitting defeat and missing a learning opportunity.  So I am asking here if it is possible to create a bevel (chamfer) between the construction line and the face of the part which projects into the box (also identified by an arrow)?
When I couldn't make chamfer work I was sure I could create a construction plane and use it to do a cut.  But I was also unable to create the right construction plane.
So .. if you can help I'd be grateful.
(Befuddled) Bob
TheCADWhisperer
You should be able to do all three solutions...
bobus17821
Thank you VERY much CADWhisperer.  My problem with Chamfer, I guess, is that the blue arrow which is part of the dialog  didn't make much sense to me.  I couldn't see how dragging it was going to accomplish what I wanted to do.  So, seeing from your file that chamfer does indeed do what I need, I just ignored the arrow and typed in a value and it did exactly what I wanted.  In your other solution I can't be certain but it appears that you drew a sketch on the edge of the part which projects into the box and then used that for an extrude/cut.  That just never occurred to me.  Brain getting too calcified!  Thanks again.  (Now Less Befuddled) Bob
