There might be an easy answer to this.
I need to create a faceplate for a lot of connectors on a PCB. I can project the outline of the connectors to the sketch, and then extrude the sheet metal and voilá, I have a perfect cutout. Except that most connectors will fit too tight. I need to grow/scale/offset all those lines by half a millimeter to ensure confortable fits. I found that some complex draws I cannot scale or offset, and while I can offset simple circles, the original line remains which bugs me. I could also break the link to the projection, but then if we move connectors on the PCB, these wont follow, so its less ideal. Is there a solution to all of this?
thanks
Balazs
