Fusion Support
Best mouse for Fusion 360 on MacBook
12 REPLIES 12
Message 1 of 13
jonpendleton57
389 Views, 12 Replies
Can anyone recommend the best mouse for Fusion 360? Are there any advantages to using a Trackball mouse rather than a conventional mouse?
12 REPLIES 12
Message 2 of 13
g-andresen
in reply to: jonpendleton57
I can recommend that you take a look at the Space Mouse.
Günther
Message 3 of 13
@jonpendleton57 it's going to be largely a matter of personal preference. However, to be fully transparent, I can tell you that the Apple Magic Mouse does not currently play nicely with Fusion 360 without first disabling Gesture-based View Navigation in Fusion's Preferences.
You're going to want at least mouse buttons 1-3, but 4/5 (typically on the side) are not currently utilized. With "CAD mice" they often separate the scroll wheel and middle mouse button (3), where most mice on the market tend to utilize a clickable scroll wheel to do the same - the benefit of separating them can be that you can hold down button 3 without risking accidentally changing zoom level.
The SpaceMouse device mentioned by the other user is generally used in addition to a mouse - it's a way of utilizing your [generally speaking] left hand to control pan/orbit navigation, freeing up the right hand to freely navigate the UI without needing to jump back to the modeling canvas.
On macOS, we also support trackpad gestures for navigation, and some Mac users opt for that over a traditional mouse.
Whether trackpad, SpaceMouse, or traditional 3-5 button mouse, you cannot go wrong - it's all about what feels natural to you.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 4 of 13
Hi Lance,
Thank you for kindly replying to my questions. I am aware of most of the options you mention except for Track Pad. I will investigate this option further. I’ve been looking at trackball mouse options and as I use a separate number pad with my MacBook, I was thinking that maybe the trackball would help cut down mouse moments and save space. Do you have any experience using a trackball mouse?
Message 5 of 13
jonpendleton57
in reply to: g-andresen
Hi Gunther,
Thank you for kindly responding to my question. I have taken a look at Space Mouse but I’m unsure whether to take the leap at the moment. Do you use Space Mouse?
Jon
Message 6 of 13
g-andresen
I currently work with a Space Mouse pro.
If I had to make a decision today, I would choose the "compact" version because I rarely use the additional function keys.
My first 3-D mouse was the Space Pilot from 3 D Connexion in 2008.
I can hardly imagine working without a 3D mouse.
günther
Message 7 of 13
I don't think that the actual question has been answered.
I think that the one mouse NOT to use for 3D modeling in general and CAD specifically is the Magic Mouse, the one mouse Apple manufactures. The lack of a distinct scroll-click wheel makes working with the magic mouse very cumbersome in my experience.
Any other mouse with 2 buttons and a scroll-click wheel should work fine.
I personally like small mice and used Razer Orochi. I have 2 of them and both have dysfunctional middle mouse button by now, or in other words the scroll wheel still works, but it does not function as a middle button anymore.
As such I migrated to a 3D connexion CAD mouse compact wireless, which has three distinct buttons and a mouse wheel.
That covers the right hand operation of a (mostly) right handed person.
My left hand usually operates a 3D connexion Spacemouse wireless.
Peter Doering
Message 8 of 13
Not as much as I'd like to. The Mac trackpad (whether in-built or Magic Trackpad) serves a lot of the same purpose for me since you need to use two fingers to trigger most movement gestures and the trackpad itself stays stationary - but a trackball is next on my list of purchases just so I can better answer these types of questions. I had a coworker in a past life who swore by her trackball for content editing, but again, it's about what feels natural to you. If you can, I would purchase one at a retailer with a friendly return policy so that you can exchange it if you dislike it.
Or, if you want to go over-the-top like I do, you could have multiple input devices connected to the same device, and switch based on your current application/context. Even though you can only have one cursor active, you can still connect multiple mice!
Lance Carocci
Message 9 of 13
g-andresen
Contact a dealer for a device to test.
günther
Message 10 of 13
I have used this mouse it is very good I recommend it to you Logitech MX Master 3.
Message 11 of 13
Bjanders
I think everybody has their own preferences, but like mentioned above, I'd look for a mouse where the middle button and scroll wheel are separated. I use an Elecom DEFT PRO trackball (https://elecomusa.com/products/b07c9t4ttw), which I like, in addition to a Spacemouse. If I didn't use the Elecom I'd probably get the 3DConnexion CadMouse.
Message 12 of 13
Each person has their own preferences, but as mentioned earlier, I would recommend searching for a mouse with a distinct separation between the middle button and scroll wheel. Personally, I use the Elecom DEFT PRO trackball and find it quite satisfactory, along with a Spacemouse. If I were to choose a different option, the 3DConnexion CadMouse would likely be my top pick.
Message 13 of 13
Bjanders
in reply to: ahsasprogram1
Why does this reply sound like a rephrasing of mine? A bot? Someone trying to earn reply points?
