What is the best method to create this design? I first tried to create each board as a component. But getting the sizes and angles correct was difficult. Also joining the components was difficult. I then tried a different approach.
I started with a new design drew the outline of the design. Then created a 1/2 offset from each line. Once the shape that is in the picture was done. I created new components and opened a new sketch. Clicked on each part did an extrude. After doing this to of the 5 parts I ended up with the below drawing.
What would be the way most designers would create this design?
