Fusion Support
Best DXF export setting from Rhino 7 to F360
2 REPLIES 2
dustinfelipejohn
120 Views, 2 Replies
  I'm sure I'm not the only one with this question but I'm mainly using F360 as a CAM controller and drawing using F360.  My usual workflow is to create separate sketches as different layers in Rhino 7 and import a DXF to Fusion 360 several times selecting each layer needed each time to create different sketches, ie. one layer for a 2D Contour (which will be the profiles to extrude into bodies) and one layer for a Trace toolpath where all sketch profiles will be selected as the Geometry for a Trace toolpath.
Given that Rhino has multiple DXF settings, sometimes the linework is a very simple import that isn't bogged down and crashes the program and sometimes it will be impossible to find the right Export settings to import smoothly.  It seems to correlate to the file size exported but I find it pretty surprising that a DXF file that is at most 2 megabytes will crash the program.
Basically I'm asking which DXF Export scheme works best for import into Fusion and "best" meaning which doesn't crash because of its size and complexity?   I've attached a screenshot of what the artwork is, and one of the dialogue box that shows the different schemes.
Greatly appreciate the help!
2 REPLIES 2
These are the settings I've found work well. Explode polycurves and split at kinks help with importing polycurves and avoid using simplify lines and arcs.
Mark
Mark Hughes
Owner, Hughes Tooling
Got to ask but for your simple example why not draw in Fusion? I'd recommended you practice doing the easier stuff in Fusion for practice.
Mark
Mark Hughes
