Bend line not showing in flat pattern
didjital-shurco
Message 1 of 13
didjital-shurco
Since today's update the bend lines are no longer showing on flat patterns.  Whats weird is the bend extents are there and can be turned on and off, but the actual bend line is missing.
Replies (12)
Message 2 of 13
jhackney1972
Make sure you are viewing a flat pattern and then expand your browser and make sure both line types have the visibility eye beside them.  I do not have any issues with either turning them on or off.
John Hackney, Retired
Message 3 of 13
TheCADWhisperer
I just tried an example part on my machine and got bend line.
Message 4 of 13
didjital-shurco
When I look at the flat pattern bend lines like you have in the image above it only shows extent lines.
Message 5 of 13
didjital-shurco
I just made a new part in a new file and it works correctly.  The file attached (the one in question) was made BEFORE the update, so maybe that's the reason?  The fender is the culprit.
Message 6 of 13
jhackney1972
I assigned one of my 16 GA sheet metal standard materials to your component and the bend lines show up.  Changed back to your assign material and they disappear.  There is something in the material definition it does not like but I cannot lay my finger on it.
Message 7 of 13
didjital-shurco
Its not a new sheetmetal rule, its one Ive been using for probably over a year with no problems.  Not sure whats going on, but it started yesterday after my fusion updated.
Message 8 of 13
madtechie
Observer
Observer
I had the same problem. For me it was the Miter/rip/seam gap setting in Sheet Metal Rules. I reduced it to close the gap on the 2 and 3 bend corners. If it's too small the bend line disappears. I think it's because the smaller seam gap interferes with the relief shape that the bend intercepts. Not sure if it's a bug or not. Hope this helps.
Message 9 of 13
salival
As @madtechie  mentioned this seems to be an issue with the mitre/rip/seam settings.
I also have this issue where I can't get bend lines but I can get bend extents.
If I suppress the earlier flange that creates my folds on the side, the bend lines come back (but obviously I lose the bends I want) unsuppress the flange and the bend lines go away again.
I would consider this a pretty bad bug
Message 10 of 13
TheCADWhisperer
Check this one (see Attached).
Message 11 of 13
salival
Thank you, that works fine, I guess you changed something to do with the reliefs there?
Cheers!
Message 12 of 13
garrettF9Q8X
Same thing is happening to me, just seems like it is only happening when I extrude the sheet metal part from a line drawing. If I create a base piece of sheet metal, then do all my brakes where they go, the lines show up.
Message 13 of 13
ksavona
Yes!!!!!!!!!!!!!!!!!!!!!!!!!!! this worked, Miter/rip/seam gap
