Beginner Confusion
panddmfg
Message 1 of 10
Beginner Confusion
panddmfg
I'm a very beginning beginner. I'm on Day 2 of this video series (learn 360 in 30 days) with the bottle project.
What I can't figure out is how do I center my drawing on the canvas. If I enlarge it via scroll wheel to see it better and work the lesson, the top goes up and off the canvas/screen. I want to enlarge it and keep it centered.
Any help will be appreciated.
Thanks.
Replies (9)
Message 2 of 10
jhackney1972
You did not attach your graphic file you are using for your Canvas but the attached video will show you a method I use to place my Canvas.  Please attach your graphic and I will work with it if you need further help.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
Message 3 of 10
Thanks, and I'm guessing this is what you want. https://a360.co/41AGRL5 That video has never started
Message 4 of 10
jhackney1972
The video that I attached has to process before you can view it.  It has done so, take a look.  As for your file, you are using a Fusion Personal License and cannot
Share files via Fusion.  Please attach the graphic file using the Attachment Section of a reply Forum Post.
Message 5 of 10
panddmfg
Please attach the graphic file  Which file would that be? I looked under 'File' and couldn't figure it out. And I thought Photoshop was complicated.
Message 6 of 10
jhackney1972
I have included an Animated GIF that shows the insertion of a Canvas and how it stays centered when you enlarge it.  This graphic does not need a sketch to center it.  Using Fusion for 2 days, it take time to learn a complex application.  I have been using it over 8 years and am still learning.
Message 7 of 10
panddmfg
Here's a pic of the bottle that the lesson is.
Message 8 of 10
Thanks, appreciate it, but does that gif have slow motion? Having trouble following it.
Message 9 of 10
jhackney1972
Here is a video you can play over and over and I created it slowly.  It is only four picks, command, file, sketch plane and then the enlarge icon on the corner.  Remember, the video takes a few minutes for the Forum to process it.
Message 10 of 10
I'll check it out. Thanks for your patience.
