Announcements
Base view is being cropped on a new drawing
geomonkey79
geomonkey79
Hi Team,
I'm trying to create a drawing of a specialty bolt.  Every time I add the part using the Base View command, the part is shown cropped.
Anyone else experiencing this problem?  Or is there something I'm missing.  I've installed the latest version of Fusion 360, restarted my PC.
geomonkey79
Here is a copy of the fusion 360 file that is causing the problem
jhackney1972
It would seem that a couple of your Fillets were corrupt.  A model is attached that will create a 2D Drawing.
John Hackney, Retired
geomonkey79
@jhackney1972  You are a scholar and a gentleman!  Thank you.  I was at a loss as to why this was happening, thank you!  Can I ask how you debugged the problem?
jhackney1972
I moved the end of part marker back in the Timeline until it did not fail then moved it ahead one step at a time until the drawing failed.  That will tell you the offending features.  The Timeline is a wonderful tool.
geomonkey79
Thanks for the tip.  Its greatly appreciated
