Announcements
Bad rendered wood appearance material on cloud rendering
macmanpb
macmanpb
I rendered a cabinet design with the cloud render in Fusion360. The result was bad. All these gray tiles.
It is my fault, how to get my cloud credits back if is not?
Here is how the cabinet should look like (not rendered):
TrippyLighting
Not sure you can get the cloud credits back, but it is a valid question.
Are you in a position to share the model ?
macmanpb
Hi @TrippyLighting, thank you for the fast response!
Here is the share link: https://a360.co/3eJ37ZZ
TrippyLighting
It looks to me that particular "Oak - Glossy" material for some reason is buggy. I tried other glossy materials like the "Cherry - Glossy" or some to the solid wood appearances and they worked fine.
Still testing a few things, though!
jeff_strater
Thanks for the model @macmanpb , and the analysis, @TrippyLighting - I've alerted the graphics/rendering team to take a look at this.
Jeff Strater
Engineering Director
TrippyLighting
@jeff_strater I tagged you on the Slack channel with another appearance problem where the cloud and local render disagree.
