Backing up all team projects
ericfrontier
Observer
ericfrontier
Observer
Observer
I would like to ensure that I can once a month backup every design file in my company's Fusion360 (even the ones that were not shared with me). I would assume this would be possible for the admin. What is the simplest way to do this?
P-BvanWyk
Good day @ericfrontier,
I haven't seen such a feature built into Fusion 360, not sure if there is a 3rd party option.
One thing I have found is to cache an entire project locally and then copy the files over from there to an external backup.
Please click on Accept Solution to help other community members solve their issues.
Also, consider giving a Like to the comments that you feel added value.
Kind regards,
Pieter-Ben van Wyk
ericfrontier
Observer
Observer
Thanks @P-BvanWyk. I am following the instructions to cache an entire project here: https://help.autodesk.com/view/fusion360/ENU/?guid=ASM-CACHE-DESIGN
It very simple to just right-click and click Add to Offline Cache. The problem is, most projects do not give me this option. The right-click menu will either say "Request Access" or "Leave."  Why is that?
In the Admin hub for the team, I am Team Administrator, and Owner, so I'm not sure why I cannot backup/cache some projects.
P-BvanWyk
On my side, I can see that the Default project cannot be cached, not projects that I don't have access to.
Could be that another user created a closed project, so you will have to request access.
For more information, you can access the project through Fusion Team on your browser.
Kind regards,
Pieter-Ben van Wyk
