Automatically modify arrayed objects based on changes to a reference object?
tae_joung
tae_joung
Hi all,
I'm stuck on how to make identical changes to all arrayed objects by modifying a single reference object.
So, I created a reference object as follows:
Then, I applied rectangular array to the reference object:
Then, I applied an extrude cut to the reference object:
front view
side view (ensuring it extruded all the way to the ground)
From here, I wanted to make the extrude cut to automatically apply to every arrayed object whenever I made changes to the reference. However, I'm not sure how to achieve this. I tried using 'Create Components from Bodies' and apply 'Combine' to all the objects and the plate to group everything into one component. I thought this would work as intended, but it didn't. Ultimately, I ended up creating circles and extruding them one by one.
Does anyone have any suggestion or know a better way to do this?
davebYYPCU
That’s what the Timeline is for.  If you have a Timeline,
move the timeline marker to before the pattern, do the mods, send timeline marker to after the pattern, the pattern will update.
No timeline, you got it - the right way.
Might help…..
