Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Autodesk Identity Manager constantly crashing
gabe5757
gabe5757
Hello. I have been recieving these error popups intermitently, even before trying to open Fusion 360 or Inventor, since yesterday. Both Fusion and Inventor wouldn't open (Fusion stuck in a white window, Inventor freezes in the splash window loading bar), immediately throwing the error message. When trying to send the report, it says that the connection has expired, and doesn't send the logs.
Today, for some reason, Fusion was able to open (slowly, but normally) in offline mode. Inventor still behaves the same as yesterday.
The only thing that stops these errors from appearing is closing Autodesk Access (which runs on startup). With that, Fusion wasn't able to start at all, stuck on the small splash window.
This problem seems to be similar to the one reported here: https://forums.autodesk.com/t5/fusion-360-support/issue-with-accessing-fusion-360-quot-autodesk-iden...
However, while the error message is the same (just in Portuguese instead of Italian), the solution proposed in the reply did not work.
There have been no updates for Fusion or Windows since the last time I opened it. The only thing that changed was connecting through my phone's access point (since I'm on the coast without cable or wifi).
Any help is welcome, and I can still provide more detail of my troubleshooting attempts. Screenshots of the error message will be attached here.
Thanks in advance,
- Gabriel
gabe5757
Update: the issue seems to have been solved now that I'm on my city home network.
I had read another post on the forum about a similar issued that also seemed to be solved after the person changed providers on their company. Which is werid, since my home provider was recently changed to the same as our mobile one, and it works fine.
If you're having similar issues as mine, try connecting to another network and maybe restart your device - basically what I did coming back from my trip.
Hope this will be helpful!
