Autodesk Fusion 360 export dxf and dwg files in a 2010 format
aloechler
aloechler
it looks like the only option from Autodesk Fusion 360 in a newer or different dxf,dwf file format.  The guys I'm working with need it in 2010 format
HughesTooling
What do you need to export? You can export sketches as R14 from the right click menu.
If that doesn't help Autodesk DWG Trueview can convert files to different versions. https://www.autodesk.co.uk/viewers
Mark Hughes
Owner, Hughes Tooling
aloechler
thanks yes I think that just might be the ticket?
found a convert to 2010 option
will update back if they accept the file.
Cheers
