Fusion Support
Autodesk fusion 360 CFD
6 REPLIES 6
jeremy_camper
322 Views, 6 Replies
Can fusion 360 and extensions due cfd?
I simulations can do fea but not sure if any do cfd
6 REPLIES 6
According to this Autodesk article, it is not a part of Fusion 360.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
I didn't think so but wanted to be wrong... lol
I was hoping there was a AFFORDABLE add on/extension/module
I know there is autodesk cfd but I believe it's pretty expensive
I know that there is no Extension available at this time.
John Hackney
Retired
Maybe one day
Would about inventor? Can you buy tokens to use cfd in it?
You can access most Autodesk Applications using the Flex Access program.  Here is a link to the Autodesk CFD application purchase site which includes a description of Flex Access.
John Hackney
Retired
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
John Hackney
Retired
