Assembly of meshes - visualization error in Autodesk Viewer
Hi, my workflow uses Autodesk Fusion 360 + Viewer in order to share projects that are essentially assemblies of STLs files. Up to two months ago all worked fine. I open a new document in Fusion 360, import various STL files (mesh objects). I need to set up different appearances for all the objects; after that, I save the project. I export the file as a .f3d file and I import the file in Autodesk Viewer. When I open the project in Autodesk Viewer, all my appereances are lost, all the objects have no custom appereances and are brought back to the "Steel" look. Three months ago I was able to see all the correct materials.
Moreover, even the names of the objects that I set up in Autodesk Fusion are lost in Viewer (the model browser reports only "mesh_name_undefined" for all the objects.
Maybe some update has broken something? Am I doing something wrong?
Thanks in advance.
