Fusion Support
Assembly joint problem
2 REPLIES 2
rlenicheck
95 Views, 2 Replies
I am getting a joint failure while trying to complete an simple animation assembly. Three of the joints seem to be ok but adding a fourth gives errors. This is totally baffling to me. Can someone enlighten me, please?
2 REPLIES 2
jhackney1972
in reply to: rlenicheck
If you try to use a Revolve Joint, which I am sure you are, it results in a problem.  This is due to a small build-up of tolerances in the revolve plane.  Use a Cylindrical Joint on one side instead to relieve this issue.  Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
rlenicheck
Brilliant. And still confusing. Thanks, John
