Announcements
Assembly intense model, used to work, now with errors and does not Rebuild the same way - buggy and can't figure out the issue(s)
polesen88
polesen88
I've got an assembly intense model with lots of joints. The model doesn't seem to be stable anymore and depending on what I do I get different rebuild errors. Originally I didn't have any rebuild errors but now I have lots. Obviously, this makes it hard to make changes and use the model. I could spend hours trying to figure out the errors but since they keep changing the situation feels hopeless to resolve. Is there a methodology to fix the model and/or ways Fusion can provide meaningful insight for troubleshooting? Some of the joints that are now failing are very simple joints that used to work perfectly.
g-andresen
A dentist asks me to open my mouth to check the condition of my teeth.
What am I asking you to do in this case?
günther
polesen88
Are you an official Autodesk dentist? I can't open my mouth publicly.
g-andresen
I notice that you have described an issue in a public forum, but expect private support.
Well then.
günther
polesen88
Well, last time I posted a problem here I received support from someone from Autodesk so...
TrippyLighting
Well, good luck then ...
Generally speaking, not having the ability to trouble shoot your own problems but working on NDA stuff and then having a smart mouth isn't a good combination!
@jodom4 @ryan.bales can you help that sunshine?
ryan.bales
Autodesk Support
Autodesk Support
If its under NDA i'll assume you are a commercial subscriber, the easiest way to get ahold of support is to create a chat from within Fusion 360 and we can take a look.
Ryan Bales
Fusion 360 Product Support
