ASSAMBLY TRANSPARENCY
I am new with fusion 360. I was doing a assemble and suddenly the assable get transparent. I dont if I pressed some command. I tried changing the material. I the model of each part looks right, the only problem is the assemble. please  see the photos of the assemble and the part to see the difference. I want to see it like the part alone.
julia.paganucci
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Thanks for posting!!
It seems like your visual style settings have been changed (this could have accidentally happened from clicking keyboard commands). Click on the computers screen icon in the center bottom of your screen, then click visual style, then click "Shaded with visible edges only". This should be the settings you want!
If this is already the setting you are on, then look at which component you have active. The top main component will show all the components with whatever visual style you have instead of isolating just the one that is active.
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
