You have an error in the placement of your parentheses. I noted this with the red arrow. I attached a corrected Parameter table to shown it works if enter correctly.
The answer to your previous question, divide by 1mm, is to change the parameter units from millimeters to no units. In a basic division millimeters, in the numerator, divide by 1mm will cancel out returning a value with no units.
John Hackney, Retired
