Announcements
Arrange Function and Capture Position
karma_coma
karma_coma
I'm having an issue where I've imported two assemblies to be CNC machined, nest optimised using the Arrange function. I always need to manually adjust things after using the arrange command as parts aren't always in the correct face up/ orientation on the sheet. So I will then use 'Capture Position' to ensure the manually moved parts don't update.
Problem I have is if I update the separate 'linked' components source files, it disregards my 'Capture Position' command and reverts components to their original 'Arrange' position. Is there something wrong in my workflow or is this a bug with linked files?
Cheers,
Leo
Phil.E
When you use Capture Position, there is a capture position icon at the end of your timeline?
If so, it may be that Arrange is not playing well with Capture Position. Could you possibly export or share one of these assemblies for me to test?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
