Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Support
Applying Hatch manually
4 REPLIES 4
rajugupta8200
216 Views, 4 Replies
How to apply hatching if it not generated automatically?
I am trying to cut the section at the center, but the hatching is not generated, If I move the position of section line away from center then hatching is generated.
I tried to check the section view in 3D, the body is fully solid and there is no sheet body  at center. section.gif
I am attaching the file, please find is there any error in my file.
4 REPLIES 4
@rajugupta8200
This appears to be imported geometry.
Did you run Validate?
I checked the body in Autodesk Inventor Professional - and this is what I found...
@rajugupta8200
Try the Attached file.
@TheCADWhisperer
Thanks for the response,
I downloaded the file what you uploaded (Whisper - Repaired Body.f3d) opened it and moved to the drawing workspace and again having the same issue with hatching.
Is there any alternate geometry checking method in Fusion 360.
@rajugupta8200
Can you request a file with history?
Show the source the obvious geometry issue that I found.
With something so obvious not noticed - I suspect that there are other issues.
Can you remodel the geometry from scratch?
