12:56 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good day
I used to be able to apply a decal to selected faces as this worked better than the chain faces option.
Below you will see a decal applied to a whole bunch of faces and worked perfectly.
After an update this no longer works. I edited the position of the decal and tried re-selecting faces as above and as seen only the first selected face was applied.
And using chain faces does not give the desired effect as well as the 1st example.
Please look into this as this is a feature I use quite often for our custom painted products.
Thank you
Franko
Link copied
