Fusion Support
Appearance overrides not visible when the component is inserted as a derive.
0 REPLIES 0
Message 1 of 1
1ncbanse
79 Views, 0 Replies
I am trying to insert a derive of a component who's appearance I modified, but when the component is inserted, the appearance overrides do not carry over into the target document. Is there any way that the appearances I change can be seen in the document I inserted them into? side note: I imported this component into fusion 360 as a .step file, and then changed the appearance and material. Also, for some reason the appearances that i overrode on components that I modeled in Fusion 360 did not experience the same issue.
0 REPLIES 0
