Appearance over ride errors
terry_fusion
terry_fusion
Is there some way to mass exit multiple error warnings on appearance issues?
I made a mistake and had 180 appearance warnings for 180 selected faces, and have to go an individually X out of each one, my god what a PIA!
I know what I did wrong and how to fix it but I ended up having to close Fusion and reopen my model just so I didn't come unglued.
Phil.E
Thanks for posting this question. I haven't seen this behavior, but it might need some testing and perhaps could be improved. It would help if you can share a copy of the design so I can test exactly what you experienced in person.
Can you export a version, or a share-link, and the steps required to replicate the issue?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
terry_fusion
Howdy,
Thanks for getting back with me on this, I've attached both a video of the error in action each flash you see on the X in the warning dialog is me closing each error message box.
I think a drop down list of all the errors with an option to select and kill them all would be beneficial.
Thanks for taking a look.
Phil.E
Thanks for the model and video. I can't reproduce the effect. When I see that warning I can dismiss it permanently by closing it only once. Sorry.
Have you tried the same workflow using the appearance dialog? It should be possible to select a set of faces, set the appearance filter to "faces" and apply your appearance to just the selected faces. It would be interesting to see if you get the same result.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
