So i am trying to add an appearance to the rim and inside of a wheel in order to differentiate it from the tyre. In the model space this wasnt working, I was only able to apply the appearance to the whole body, so i tried splitting the face, this worked however it also applied the appearance to the outside of the wheel for some reason??
After this I went back into sculpt/form (where i could select the desired faces) and applied the appearance to the faces, happy with the result i went back into model to find it was gone.
I dont see why Fusion would allow you to use the appearance feature in the sculpt mode if you couldnt retain it afterwards? Is this a bug?
I have attached two photos, one showing the wheel in the form mode with the desired appearance applied to the faces i wanted, the other showing how you can only select the entire body in 'design' mode.
Any help appreciated.
