Apparently sketch problems
I edited an image in Photoshop Elements because some of the thin parts were too thin when cut. I then saved it to an SVG file in Inkscape and imported to F360. I had all the different color lines as you see in the image. I thought I may have saved it as an Inkscape SVG so I saved it again as a plain SVG. You can see that the line in the sketch have changed, but apparently there are still gaps in the lines. In the first one (maybe Inkscape SVG) I zoomed in and found places with multiple lines. When I deleted one of the extra lines in sketch mode and then moved to another area the extra lines were not visible.
Do you think there is a problem with the imported SVG or do I just need to repair the sketch in F360?
