Apparently sketch problems
Cad4fish
Cad4fish
I edited an image in Photoshop Elements because some of the thin parts were too thin when cut.  I then saved it to an SVG file in Inkscape and imported to F360.  I had all the different color lines as you see in the image.  I thought I may have saved it as an Inkscape SVG so I saved it again as a plain SVG.  You can see that the line in the sketch have changed, but apparently there are still gaps in the lines.  In the first one (maybe Inkscape SVG) I zoomed in and found places with multiple lines.  When I deleted one of the extra lines in sketch mode and then moved to another area the extra lines were not visible.
Do you think there is a problem with the imported SVG or do I just need to repair the sketch in F360?
g-andresen
please share the SVG files
günther
TheCADWhisperer
@Cad4fish
Cad4fish
I have since found an error I made in Inkscape that apparently caused all the problems in the sketch. Fixing that solved the problem.  Thanks for the reponses.
Cad4fish
I never got to the point of saving an f3d file.  I later realized I forgot a step in tracing the bitmap in Inkscape and was introducing errors in the SVG file.  Now that I got that corrected the image inserted correctly.
Thanks for the response.
