Fusion Support
another upload stuck
2 REPLIES 2
lmlosco
101 Views, 2 Replies
goodmorning,
there are several days that I cannot able to upload new project, I'll try some solution in this forum and not work for me,
in my log I find
20230627T083839 D 6084 LaunchDarkly: [C:\Windows\Temp\releaser-project\src\ldnet.c, 527] curl_easy_perform returned error code 56
20230627T083839 D 6084 LaunchDarkly: [C:\Windows\Temp\releaser-project\src\ldnet.c, 517] connecting to stream https://clientstream.launchdarkly.com/meval/eyJrZXkiOiJlSWpmNUZ1UElEQkNqMlFVdUs3b29ZWmVkU1k9IiwiZW1h...
20230627T083839 I 13836 GET 200 https://frv.ui-dls360.autodesk.com/api/v1/checkAccess - workflow:Extensions attempt:0 requestId:f360_Extensions__1-649a83ef-9a59b1bd810b4f518f70146d dt=0.62
20230627T083840 E 28496 Network failed request - response NOT OK:
URI:https://developer.api.autodesk.com/fhq/v1/spaces?type=FLC&fusionId=urn:adsk.fusion:scope:f3309e7d-0f...
...X-Request-ID: ContentBrowser_07b8f6e1-d6d1-4ab6-85a4-432f7beb5600__GET_FLC_URN_GET_FLC_URN
...response: HTTP/1.1 404 Not Found
Connection: keep-alive
Content-Length: 375
Content-Type: application/json
Date: Tue, 27 Jun 2023 06:38:42 GMT
Strict-Transport-Security: max-age=31536000; includeSubDomains
X-Content-Type-Options: nosniff
X-Frame-Options: DENY
X-XSS-Protection: 1; mode=block
{"requestId":"ContentBrowser_07b8f6e1-d6d1-4ab6-85a4-432f7beb5600__GET_FLC_URN_GET_FLC_URN","httpStatus":404,"detailedMessage":"Not able to find any SPACE with given search parameters","errors":[{"type":"errors","code":"FHQ-404","message":"Not able to find any SPACE with given search parameters","links":{"self":"https://developer.api.autodesk.com/fhq/v1/errors/FHQ-404"}}]} ThreadID: 28496, Function: Ns::Network::ReqUtils::logRequestError, Line: 320
please help me, thanks
2 REPLIES 2
johnnyL4KW5
in reply to: lmlosco
Try logging out and then back in. had the same issue yesterday. Nothing else worked.
lmlosco
in reply to: johnnyL4KW5
sigh!
not works
