Announcements
Another parameter dialog bug - typing in search field jumps to name field
Julie_7
Message 1 of 1
Julie_7
When I click in the filter field on the parameters window, often part of my typing ends up in some name field. It doesn't always happen or I would not be able to filter parameters. It does happen quite regularly, and when it happens it might happen again and again in sequence while I keep trying to filter.
If you look at the image below, I clicked in the filter text box and quickly started typing the word label. You can see that the first two letters were in the correct place, but then the b went into a name field. Usually it is just the first letter in the filter and then it jumps to some name field.
In this case I took a screen capture and it somehow changed the state of the parameter dialog to accept the b so I can't even undo the change. I wish I could remember what the name was. I do know that the modified name did not have the word label in it.
Replies (0)
