Another design trashed by Derive!
OK I'll try again, I've reported 4 or 5 times on the forum about designs being trashed because I can no longer "Get Latest" in a derived design, not once have I had a reply from anyone at AutoDesk.
Really coming to the conclusion Derive is too unstable to use for production work and should be avoided! Didn't make any edits to the source design, just added so new components. In the previous problem designs I think edits made changes to bodies within a component so originally a component had Body1 but after an edit splitting or joining I the component ended up with a different body number.
Here's the latest error report. Thank you for sending your error report CER_223692476 to Autodesk.
Mark
Edit 1.
Just made a copy of the folder to a project I can share with AutoDesk and tried updating the copy and get the same crash.
Edit 2.
Looking at the copied version it's not going to be any use to support as although I have new copies of all the designs, the derived designs are linked to the original designs not the new copies. So pretty useless, same as copying a project with 2d drawing, the 2d drawing end up linked to the old designs not the new copies.
Thank you for sending your error report CER_223693053 to Autodesk.
Edit 3.
Tried running a Compute All in the derived design and Fusion crashed again. So seems like there's something wrong in the derive design and trying to get latest is probably doing something similar to compute all while updating?
Thank you for sending your error report CER_223693971 to Autodesk.
Mark Hughes
Owner, Hughes Tooling
