Fusion Support
Another Bug
3 REPLIES 3
TheCADWhisperer
181 Views, 3 Replies
Another Bug
I was investigating alternatives to avoid this reported bug https://forums.autodesk.com/t5/fusion-support/bug-coincident-constraint-not-working-on-endpoint-of-o...
and found another bug.
3 REPLIES 3
Hello @TheCADWhisperer
Is this still reproducible if you try to create a new model?
I can see the issue in the "Another Bug" model that you attached but I wasn't able to correct it resolve it within that model. When creating it from scratch, no matter which workflow I followed, I wasn't able to recreate the sick extrude in the timeline. I also tested the model by deleting the two extrudes and then recreating them which worked without issue.
Samuel Temple
Senior Software QA Engineer
(samuel.temple@autodesk.com)
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
@samuel.templeUCPAE
I just tried to reproduce the issue from scratch in a new file and it worked fine this time.
Edit - I just noticed that I inadvertently had 2 selections in my original file.  That was a mistake on my part.  I thought I had Ctrl unselected the circle as part of the Thin Extrude.
Hey @TheCADWhisperer
Not a problem at all. It is very easily done, especially when some closed profiles get automatically selected when opening a command. Glad that everything is ok now.
Samuel Temple
