Announcements
Another BUG with referencing a moved component.
HughesTooling
Consultant Consultant
HughesTooling
I've reported several of these types of problems working with components that I've positioned with a joint. In the screencast I try setting up an offset plane using the To option and get incorrect offsets and the option changes back to Distance when I click OK. File's attached with the timeline marker at the problem Offset Plane.
Mark
Mark Hughes
Owner, Hughes Tooling
Phil.E
Thanks. It looks like the (to) option is not working with any sub components. When the options is used between bodies in a single component it works as expected. This can be logged as a bug now. (FUS-97796)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
