animation translation glitch bug
resdog76
resdog76
Hello, aside from the navigation bar being very limited in regards to maving and aligning components precisely during animation it completely bugs and will move my pieces to a completely different spot after hitting ok
dsouzasujay
Hi @resdog76
Could you please check if you have 'Capture Position' after moving the components?
If you still see the problem, then please share the export by File>Export *.f3d/*.f3d file to your local drive and then attach it here to a Reply.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
