Animation Element Flickers When Fading Visibility
FusionUzr
FusionUzr
Can someone please tell me why certain elements in an animation flicker when their visibility is being faded to zero. The attached video includes an example of this flickering behavior. Note how the "Bead Structure" element flickers on & off before fully fading out. This flickering behavior happens with one or more elements in virtually every animation I create. It degrades the quality of what otherwise would be a very effective animation tool. Are there any steps being taken within Autodesk to address this issue?
FusionUzr
As a follow-up to my post above, I've read some other posts that suggest this flickering problem is related to an issue with the use of darker blue Appearance colors. So I tried changing the dark blue/green color used in the original animation of the Bead Structure to a burnt orange color. As can be seen in the attached video, this change made no difference to the flickering behavior of the Bead Structure fade-out animation. It does not appear this issue is related to the choice of Appearance colors used in the animation.
Having the same issue.
Very annoying.
When it's not one bug it's another!
