Message 1 of 9
Aluminium milling problem Fusion Winpcnc
I'm trying to mill a 5mm aluminium piece in 0,5mm steps.
Data:
Spindle speed: 12000
Vadvance: 60mm/min (feed rate on 50%, later on 15%, in both cases problems)
Mill: 2mm diameter, 2 flutes (VHM)
I was wondering if these speeds are okay or not.
I'm also confused about the fact that apparently I have a feed rate in Winpcnc (Vadvance) and in Fusion (cutting feedrate (200mm/min))
The problem is that in the first case (feed rate 50%) my mill breaks and the cut is not smooth, in the second the cut is not smoot and wide. I stopped it before it could brake.
Could you tell me what I do wrong? I'l send you the file with all the information.
Best,
Maud
