I'm curious if there is anyway to copy components and position them similar to a mirror effect for non-symmetrical designs. I use fusion for modeling furniture and would like to use it to make my build plans as well. A lot of the pieces I model typically consist of a base and some type of cabinet on top of it. Recently I did a model using mirroring and mid-planes which worked great for modeling, however it blew my parts list up and made it unmanageable due to all the added components. I'm unable to simply copy & rotate certain parts because they are offset from my origin due to the base. For example, I could copy & rotate the sides of my cabinet because I have the Y-axis to reference. However, I'm not able to do this for the top and bottom of the cabinet because I don't have a centered axis to reference. This is where the mid-plane and mirroring works great but now I have 2 parts on my part list that are exactly the same.
I've also tried things like point to point but found once I start changing my parameter values things start getting weird.
I would appreciate any tips you have! I've also attached my file to better show what I'm working on.
Thanks!
