All menus are gone after uptade
grossello
Observer Observer
grossello
Observer
Observer
Any suggestions to fix it? Fusion just rebooted after update and now I cannot see any menu on top of the screen neither the data panel.  thanks in advance
dan62Q5E
There's a thread going on here with some promising leads. TLDR; You can change the language in preferences and get most of your UI back as a workaround but so far there's no definitive solution.
grossello
Observer
Observer
thanks for the suggestion. I did not see and final solution. My only workaround for now was to change the language as suggested by other member but my Italian is not the best. I am hoping that Autodesk is working on this issue now.
HughesTooling
There was a new release last night that should fix this problem. Make sure you have the latest version v 2.0.10032
Mark Hughes
Owner, Hughes Tooling
HughesTooling
See this post for update info.
Mark
Mark Hughes
