Announcements
Align Tool: Changing "angle" sometimes "flips" instead
FrodoLoggins
FrodoLoggins
So if I align this part and then click the angle button to rotate it 90° the part actually gets flipped instead sometimes. Issue does not seem to persist if the flip button is pressed (unless the align tool is closed out before being applied):
Uploaded .f3d model was saved prior to using the Align tool.
16" M1 Max rMBP
MacOS 12.2.1
Fusion 2.0.12392
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Replies (8)
Steven_Gao
Thanks you for reporting this issue! Yes, it looks like a bug for the Angle's change. As you said, if you click the Flip button and then change the Angle, the issue is gone. Let me log a defect to track this issue.
Steven
Steven_Gao
An internal defect(FUS-99810) has been logged to track this issue.
Thanks again!
FrodoLoggins
No problem. Got another one for you:
Latest Fusion
Latest (3rd) Ventura developer beta on M1 rMBP
FrodoLoggins
FrodoLoggins
Steven_Gao
Thanks for the additional cases. I already attached them into the internal defect now.
Steven
FrodoLoggins
Hi no problem. Here's another example if it helps. f3d attached.
Public video linked her because this forum thinks the video is private:
https://youtu.be/7DQxG2EVVew
FrodoLoggins
This seems to have gotten worse with time and and much worse after the last update. Would more examples of this help?
