Fusion Support
Align and Align Component Tool Change makes more difficult and less intuitive workflow
0 REPLIES 0
Message 1 of 1
zachmck
86 Views, 0 Replies
I am not exactly sure when this change happened, but I noticed it within the last couple months. When trying to align the position of 2 bodies in Fusion, normally I would select 2 faces, then right click and hit align to snap the parts together without the need for making a joint constrain.
This is an especially handy tool in huge assemblies in order to make them workable in Fusion. However, instead of the 2 highlighted circles aligning like they used to, which took the current orientation of the part into account when alignments were made snapping them together top to bottom, Fusion now takes the origin alignment instead of the current alignment into account which results in the part flipping upside down and clipping into the other body.
I'm not sure if this was an intended change in Fusion, but if there is a solution to switch back to the old align tool, it would be appreciated.
Zach
0 REPLIES 0
