Fusion Support
AI Drawings
10 REPLIES 10
Message 1 of 11
90210111
247 Views, 10 Replies
AI Drawings
I've seen that there's a new feature that Fusion360 can make auto drawings,
for some reason I dont get it (I'm a paying customer)
When will it be out ? I want to use it!
10 REPLIES 10
Message 2 of 11
jhackney1972
in reply to: 90210111
You did not mention what Version of Fusion you are using.  Go to Help, About and check against the latest shown below.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 3 of 11
TheCADWhisperer
Message 4 of 11
90210111
in reply to: TheCADWhisperer
this is what I get:
Fusion 360 2.0.17954 x86_64
Message 5 of 11
90210111
in reply to: jhackney1972
you're right, my mistake.
here it is - Fusion 360 2.0.17954 x86_64
Message 6 of 11
jhackney1972
Your Fusion version is not up-to-date so you are not seeing this new feature.  Click on Check for Update under the Help (?) icon.
John Hackney
Retired
Message 7 of 11
90210111
It is updated
Message 8 of 11
jhackney1972
There is another issue with your updater because the version number you posted does not match the one I posted in an earlier post which is the latest.  Use the service Utility to repair your application
John Hackney
Retired
Message 9 of 11
bentwookie
FWIW, I've found that "Check for Update" is sometimes late to tell me that there's actually an update. For example, I was watching for 2.0.18220 the other week. My Mac picked it up, but when I went to my Windows box to fetch it, the dialog said I was up to date on the previous version. It was only after I opened and closed Fusion a couple of times that I saw it come down.
You might restart fusion a couple times and see it shakes 2.0.18441 loose.
Message 10 of 11
90210111
in reply to: bentwookie
Ill be waiting , working on windows , hope it works the same ...
anyone from Autodesk can help ?
Message 11 of 11
90210111
This solved the update issue - thanks !
