Message 1 of 14
05:11 PM
I am seeing problems with Pipe after the latest update. It seems like it is stuck on chain selection even when its not checked also it will make the pipe solid even when hollow is checked and section thickness is filled out. I have found if you toggle the chain box and the hollow box on and off and then select your line it seems to work correctly. Then if you use pipe again on another line you have to toggle the boxes again.
