Fusion Support
Report issues, bugs, and or unexpected behaviors youโ€™re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
After May 28 update I can't move components using the move tool.
2 REPLIES 2
jgarzagu
136 Views, 2 Replies
Hi all,
After May 28 update (2.0.19426 x86_64) I have been unable to move components once I place them in another design. After I place components for the first time, I can move them, but once I press enter and try to move them again using the move tool, the components don't move.
Maybe I'm doing something wrong, but if I recall correctly, I was able to do this in previous versions. Any guesses of what's the problem?
Thank you! ๐Ÿ™‚
Labels (1)
2 REPLIES 2
jgarzagu
in reply to: jgarzagu
After turning "Ground to Parent" off in the component options it worked again! I think it's a new future, I didn't know about this future. ๐Ÿ™Œ
davebYYPCU
Youโ€™re correct, flexible components, were removed only for 1st component in Assembly files, with the new Pin and Ground to Parent has changed it a full 180.  Can be switched off.
Might helpโ€ฆ.
Technology Administrators
